Posts: 74 |
I think this will be an easy question. I'm putting the door handles and window cranks back on the car. The door handles take the "shorter" escutheons and the window cranks take the "taller" escutcheons. My question is which ones are used on the rear quarter window? Also which type is used on the windshield crank? thanks
Posts: 980 |
The quarter window regulator handle plate and door window regulator plate are the same, part number 4210190 for 1929-32.
If you have old Chevrolets, other old Chevrolets will find out where you live.
Posts: 74 |
Is that the same part as the windshield crank plate as well? Thanks
Posts: 731 |
the short one worked on the windshield crank on mine
Chevrolet
Valve In Head, Ahead In Value
