#171838 04/27/10 07:57 AM
wawuzit Offline OP
Will any female reciver work or does it have to be 6V ? I have the male lighter, looking for the receptor. Someone said they thought it was universal ,the voltage is all that matters on the female part. THANKS.
BTW.. I need one if you have one laying around.
wawuzit@comcast.net
wawuzit #171920 04/28/10 06:51 AM
To my knowledge the female part is voltage universal but the male plug is voltage sensitive. There are several variations in size though.
tonyw #172170 04/30/10 07:39 PM
K10 Offline
6 volt and 12 volt receivers are not the same. That's for a reason. The 6 volt socket (and Lighter) is larger than the 12 volt units. You can't physically put a 6 volt lighter into a 12 volt plug. But a 12 will fit into a 6, but sloppily.
There are only 3 variations in socket size. 2 sizes for 12 volts and 1 size for 6 volts.
As an aside, I put an inverter (6 volts to 12 volts -positive ground) in order to run 12 volt accessories like a gps and a cell phone charger for long trips. inverter
So therefore I replaced my 6 volt socket with a 12 volt socket (from a local FLAPS) and it works great.
