Posts: 168 |
I have a stone guard on my '31. The bowtie emblem fits into a bracket that is connected to the radiator housing by a hex head screw. That screw is as tight as it can go, but the back plate still wobbles and so the bowtie emblem is always crooked. I began to loosen the bracket but got scared and stopped because I can't see if that screw goes into a nut someplace in the back where I can't see it and by removing the screw, the nut will fall into some "black hole" and I'll never see it again!If I knew I could safely remove the screw then all I would need to do is put a washer behind it and it'll tighten up.
Can someone tell me how that backplate and screw are attached?
Gotta31 (and a lotta questions) :confused: :confused: :confused:
Posts: 168 |
Oh, glorious sage of Chevy Heaven. I cannot tell a lie cuz you'll know it!! No,your humble servant has not purchased a set but tomorrow a.m. I'll be call the Filling Station. Howzzat?? Gotta31
Great....and while you're at it, order a 1931 owner's manual, shop manual, Fisher Body manual, and a 1929-32 parts book if you haven't already done so. :cool2:  :p
Posts: 168 |
I have all of the above except the Fisher Body manual.
Gotta31 :p :p :p
Posts: 168 |
Where were you when I needed some encouraging words?? :p  :p gotta31
