Hi to all. Is there a mounting pad or some kind of cushion or maybe some slotted shim stock, that fits between the radiator support frame and the cars frame? Right now its frame to frame. This is for a 1937 MD. Thanks,
____________________________
Joe's 37
The radiator mounting is designed to add or remove spacers in order to either raise the radiator or lower it. Once you have a good alignment of the sheetmetal you can tighten the two bolts that will hold the spacers in place.
Agrin devil
Thanks Ray. I just thought that there was some factory made spacers that could be used. Good Ole slotted out washers will do just fine.
_________________________________
Joe's 37
