Posts: 168 |
I didn't know if I should continue the Alemite thread I started or start this one. Anyway,the adapter you put on the end of a grease gun that has Alemite on one end and regular on the other, puts more grease outside the joint than it does where the grease is supposed to go! In order to get this problem corrected, I took mine to a machine shop and had them lop off the regular fitting side and thread it to match the grease gun hose threads. This way,I doesn't leak as bad when you start pumping grease into the joint. :eek:
Just FYI
Posts: 168 |
Where did you get it. I want one!  back atcha!!
Garry Wallace and Restoration Supplies have the adaptor.
Posts: 168 |
yeah, but his has the zerk fitting on the other end.
gotta31
Posts: 11,162 |
I bought one of those a Zerk that snaps onto a standard Zerk coupler and the other end is a Alemite coupling. Import made for Gary Wallace at $25, probably China made. The alimite worked on the first two fittings then began leaking like crazy, the small brown washer came out and the thing never worked again for me, I had to fasten the junky thing in a vise to get it to release it's hold on my grease gun. I gave up and bought a handful of good old Zerk fittings from NAPA and pulled the Alemites and replaced them with modern type (60 year old)Zerks...so much for being "old timey" but I can do a grease job without having grease all over me and the floor of the shop.
Posts: 238 |
Why not use original pin type Alemite grease guns? I've bought a tool kit size one and a shop size one on eBay for reasonable prices. My '29 Coach was converted to "modern" zerk type fittings sometime in its past. And I am slowly retrofitting it back to Alemite pin grease fittings.  :love: 1929 Chevrolet: A Six in the price range of a Four! :love: 1929 Coach
Capt. Harley
Posts: 566 |
Hey Mack!
I bought one of those adapters from Gary Wallace for $10 and it works great!
Four doors are great
Hoppy
Posts: 2,576 Likes: 2
Posts: 2,576 Likes: 2 |
agree with capt harley.the original alemite grease guns work great and are on ebay and in local antique malls. mike
Posts: 11,162 |
I know, since I have about 6 different Alemite ended guns in my collection of grease guns! That don't mean I have to us them.
:confused: :confused: :confused: :confused:
Posts: 168 |
Hey Heppy: I don't know what type you bought but the one I got from him has the zerk fitting on the other end and like Mack said, it pumps grease out of both sides and not where its supposed to go.And the zerk fitting holds on to the grease gun like a monkey with a fistful of peanuts! Also,since the grease is coming out of both side of the fitting, it means less oomph to put it where it needs to go.
Doug, thanks for the Alemite website. They have wat I want.
Capt Harley: Where on EBAY are they listed?
Posts: 238 |
GOTTA31, I don't remember exactly where on eBay I got mine. But look under: grease gun, alemite, antique Chevrolet, 1929 Chevrolet, 1931 Chevrolet, etc., etc.  1929 Chevrolet: Most Outstanding Chevrolet In Chevrolet History 1929 Coach
Capt. Harley
Posts: 11,162 |
I found all kinds of Alemite grease guns at old junk stores around the country, it has got so bad going there that my wife now carrys the money so she can pay out while I am loading the junk! I think that is why she carrys the money!
Posts: 168 |
Hey Mack: You got a spare one laying around that's in WORKING ORDER you want to get rid of before your wife uses it for a battering ram on your gourd?? GOTTA31 :rolleyes:
Posts: 11,162 |
Working order, now that is the debatable quality of most of the old grease guns.......If I really wanted to pursue that process I would try to buy a new one from Alemite with a 1/8" pipe thread so I could screw it onto a modern Lincoln or Alimite gun via a 12 or 18 inch flex hose.....
Posts: 168 |
O.K.---I've got a Lincoln pneumatic grease gun with a flex hose on it. So I'll order just the alemite pin-type ends and put them on the rest of my grease guns. I really wasn't after an antique for collections. I just want some working grease gun ends. Thanks for the help and info. I'm learning more everyday from all you guys. Gotta31
Posts: 168 |
CAPT. HARLEY: THANKS FOR THE EBAY HINTS ON WHERE TO FIND THESE GREASE GUNS. GOTTA31
Posts: 238 |
GOTTA31, My pleasure I hope you find one. I do not live far from Tampa, when I'm home from working out of town. Maybe we can get together sometime and drink beer and swap lies about Chevy's.... :) 1929 Chevrolet: Most Outstandin Chevrolet of Chevrolet History! 1929 Coach
Capt. Harley
Posts: 168 |
Hey Capt. I sent you an email. Gotta31
Posts: 238 |
GOTTA31, Got your message, will reply soon.  1929 Chevrolet: A Six in the price range of a Four! 1929 Coach
Capt. Harley
