Posts: 415 |
Hi All, I'm putting new front wheel bearings on my 37 MD. As I was taking off the bearing hub, A question came to mind. When I put this back together, how tight do I put the castle nut on? Is there a torque spec on this? or is it tighten to one click of the elbow then back the nut off a couple of notches? Any help on this will be appreciated. Many Thanks, ___________________________________ Joe's 37
Posts: 415 |
Thanks for the Info DOG! Now I can get out to the garage and GIT ER DONE!! __________________________________ JOE'S 37
Posts: 1,919 |
Question, Ball bearings or tapered roller bearings? The procedure is different.
Posts: 415 |
Hi 32Confederate, That would be for the old ball bearing type. ___________________________________ Joe's 37
Posts: 7,046 Likes: 107
Posts: 7,046 Likes: 107 |
Posts: 415 |
Hey Thanks Tiny, I keep forgetting about these on line manuals. _____________________________ Joe's 37
