OK . I give up. It's either ask for opinions or I put a bullet in it. I have a '53 truck. Gauges were out of dash but included when I got the vehicle. It was a started but not finished restoration. Gauges were in boxes and looked new with some age. Installed gauges and now doing final wiring. (New?) fuel gauge...bought and installed NEW sending unit. All new wiring but I'm getting a bad reading on the gauge...just above empty when I KNOW it's got at least 1/4 full tank. I've run all the traps....sending unit in/out cannot manipulate the gauge by moving the float lever. POSITIVE everything is grounded. Gauge in the cluster...gauge out of the cluster....gauge OUT OF THE TRUCK and bench tested...same results. Meter tested the sending unit. It's good. NOW....I buy a NEW gauge...repeat all the above and STILL GET THE SAME results. One thing is bothering me: When the power is on to the gauge, BOTH posts become charged...which means I'm sending live power back thru the sending unit into the tank....there's something fundamentally wrong about that picture. I get the same results regardless of the gauge I use; the original or the new.
THIS AINT THAT DIFFICULT but I'll be damned if I can figure out why nothing's working. I find it highly unlikely I have two bad gauges giving me the same results when I KNOW one of them is new. But yeah, I'm ready to put a bullet in it.
