#168673 03/21/10 05:13 PM
Dose Anyone Know If The Oil Pick-up Screen Uses A Clip Or Something Of The Sort To Be Held On!?
A stiff wire is used. It has a hook at each end. The one end hooks into the hole on one side of the tin "cup" the screen sits in. On the other side there is a slot that the other end hooks into. It crosses under the screen
WTF Did mine go! Well guess im gonna have to try and make one! Is it pose to be a tight fit in the tin "cup" or dose it have as long as he stiff steel rim of the screen is in the "cup"
THANKS NUT!
Noah
I'm sure I must have a spare somewhere. You interested in one if I can find it for $5?
Dale Carter
VCCA #8661
1948 Fleetmaster Convertible
1948 RHD Stylemaster Sedan Delivery
1948 1-Ton Tow Truck
1967 Camaro Coupe
YES VERY MUCH SO! I wont have to make one then and I can not find one for sale anywhere.
THANKS DENNY!! That Helps ALOT! Anyone Know If There Is Suppose To Be A Gasket There? Obsolete Offers a "Oil Pump Screen Gasket"
There is a small round gasket between the oil pump and the block. There is an oblong gasket with a round center hole and two side holes for screws. This gasket goes between the tin cup and the oil pump. Looks like a real small thermostat housing gasket.
THANKS AGAIN GENE!!
I finally located a spare. You can send me your address via a PM here in Chevy Chatter or feel free to email me at decarter@aol.com and I'll get it in the mail to you tomorrow morning.
Dale Carter
VCCA #8661
1967 Camaro Coupe
