#168689 03/21/10 08:17 PM
Help crazy
The tranny on my '29 Coach is leaking "big time" out of where
the speedo cable screws on the U-joint housing! mad Does anybody know where I can get a replacement seal? I tried to
cobble up one, but it ain't working. Any help would be much appreciated. Unable to find the critter listed in a 29-34 Chevy reprinted parts manual. There was the remnant of one contained in the speedo cable housing end that screwed into the U-joint housing. Thank you
Capt. Harley
Don't think they had a seal originally. Check out this discussion from a few years back. My 30 Coupe leaks there also, and I haven't found a really good seal to stop it yet.
https://vccachat.org/ubbthreads.php...ter/Search/true/Re_Speedometer#Post14717
There never was a factory seal at that location, that's why it isn't listed in the parts book.
You can get a thick piece of felt and make a seal. Many dudes have tried that and it seems to work well. Also, we have talked about different types of homemade speedometer seals here previously so you might want to do a search on Chevy Chatter for some other ideas as well.
Good Luck!
[Linked Image from i244.photobucket.com]
this is what I used. seems to work pretty well. I have extras, PM me if interested.
the 1/2" thick felt goes in first and the nylon washer secures it in place
Chevrolet
Valve In Head, Ahead In Value
Thanks guys for the info and "Dads 31" I've sent you a PM. cool
Capt. Harley
