Posts: 1,049 |
Hey guys and gals got these for fun, do they look like they would fit my 27 chevy if so need 2 more. They would look great on the wall also. Thanks in advance Ken 45145 ![[Linked Image from home.comcast.net]](http://home.comcast.net/~cpaxirs/pwpimages/wheels.JPG)
I have a 1927 Chevy Capital AA 4 Door also a 1927 Chevy Touring car, a 1936 Chevy 1/2 ton and a 2010 Corvette LT3 Convertible and a 1953 Packard Caribbean. My tow car is a 2011 Suburban.
Posts: 105 |
Ken,
They look like 27 wheels to me. The photo is a bit dark, but they seem to have the long slots in the rim for the Jaxon clamps which, I think, were first used about 1926. I cannot pick from the photo whether they are front or back wheels - if back, check that they are not cracked along the corner of the keyway before you put them on the car. In my experience this is a common fault, and while not dangerous (because the crack always stops at the hub flange) they cannot be properly seated on the axle taper, and will eventually work loose with possible key and axle damage.
Frank.
Measure the width, if 2 1/2 inches they are 1927 and older. The 1928 is easy to identify as they are 3 inches across. I would not choose to use the wood spokes on the 1927 if it is a closed car. You will feel more safe on the disc wheels.
Posts: 1,049 |
Hi guys and gals here are more pics, 2 1/2 inch measure what dimension width of rim ? is brake drum different on wood spoke? thanks in advance Ken 45145
Posts: 597 |
Brake drums are different than disc wheels
It's not how fast you can go, but how good you look at 20 MPH.
Posts: 105 |
26/7 disk wheel brake drums are different from wood wheel brake drums, but the complete wheels with correct brake drum for the wheel type are interchangeable for those cars - a 26/7 front wheel (no brake drum) won't fit on a 28 stub axle though.
The 2 1/2" dimension is the width of the felloe. The wheel in the last two photos is a 26 or 27 wheel. The front wheels on the 28s were fitted with a brake drum and the 28 felloes, as mentioned by a previous poster, were 3" wide so a wider tire could be fitted.
Frank
Posts: 1,049 |
Hey Guys and Gals more rookie questions, so the front spindle on the 27 will work on either wheel wood or metal? back needs different drum. rear wood spoke wheels have spline inside hub for drive axle front do not?
Either hub (spoke or disc) will work on the front wheel of a 1927 and older. On the rear wheel the spoke and disc have different drums which must be matched to the correct one. Front axle also has a spline and uses a square key like the rear.
Posts: 1,049 |
Guys and Gals
what is the fastest way to tell if its front wheel or rear with wood spoke?
If it looks like it has never had a brake drum attached it will be the front. The rear spoked wheel will either show evidence of a drum or still have a drum attached. A front drum will have a curved lip and has the inside machined for a brake shoe. The rear drum will have a sharp lip and will be machined on both sides. The top wheel above in the picture appears to be a front. A close inspection of the bolts will tell the tail.
Posts: 105 |
Quote:
"what is the fastest way to tell if its front wheel or rear with wood spoke?"
If the hubs are in the wheels the fronts have housings for ball bearings as in your photo above. On the back wheels the hub is tapered with a keyway. There are no bearings in a 26/27/28 back hub.
If the hubs are missing from 26/27 wheels, the hole in the middle of the wheel for the hub will be 1 3/4" diameter for a back wheel and 2 3/8" for a front wheel.
Frank
Posts: 1,049 |
any thoughts on these are they rear and for what car thanks in advance Ken 45145
Posts: 105 |
Ken,
The top one is almost certainly a front hub, since it has the housings for ball bearings (see my post above). Can't see the back of the second one to be sure, but from the way it is sitting in the photo it is probably also a front hub. They don't look to me to be 26/27 Chevrolet though. You could check the diameter of the spoke seat (posted above) to see if they might fit, but if it was me,I would be looking for known hubs of the correct years.
Also be aware that if you get wooden wheels without hubs, the hubs from disk wheels, even the same year, will not fit - the hole spacing for the hub bolts is different and the wheel offset from the hub is different, so wood wheels cannot be modified to fit the disk wheel hubs. You would need the correct hubs for wood wheels.
Frank
Posts: 1,049 |
Hi guys and gals any pics of rear spoke wheel hubs with or without drum ? I have evolved my thoughts to the point of thinking that the rear wood spoke hub would have no bearings as the bearings would be in the brake drum. I am trying to visualize the spoke to drum connection, during my break from work, much overtime right now.
Thanks Ken 45145
Posts: 105 |
Ken,
The bearings for the back wheels are in the axle housing, not the wheel. The back hub only has a tapered hole which matches the taper on the back axle. The weight of the car is taken on the axle, and from there by the bearing in the back axle housing. If you are unlucky enough to break a back axle (rare) you will lose the wheel!
There is a keyway in the hub which matches the one on the axle. The key between the axle and the hub provides the drive from the axle to the wheel hub, and the six hub bolts transfer the drive to the spokes. The round tenons on the spoke ends transfer the drive to the felloe, and one of the rim bolts transfers it to the rim and tire via the fitting which allows you to lock the two ends of the rim in place after changing a tire.
The brake drum is held on by the six hub bolts, and is actually part of the hub, because the spokes are sandwiched between the brake drum and the hub flange. It has no bearings, but is solid with the wheel.
I do have some photos of (cracked) back hubs but cannot access them at the moment - they are on another computer. If you PM me an e-mail address I'll try to send you a couple when I can get at tho other hard disk (hopefully I will remember!).
Frank
Added after seeing Arend's photos: His third photo of the wheel with the back hub showing the keyway should help to make the difference between the front hubs which you have, and the back hubs easier to recognize. In that photo you are looking at the small end of the tapered hole in the hub, i.e the outside of the wheel.
Frank.
Posts: 322 |
Posts: 1,049 |
Guys and Gals Thank you for all of your help on this matter. Your guidance has saved me the time required to figure it out myself, could have been huge. Thanks.
on the side anyone know the maker of the winged hubcap on the hubs without spoke? Or yr of hub. Thanks.
Also looking to buy a set of rear spoke wheels with drum, will pay top dollar, send private message if you like.
As for now will put them on the wall
Ken 45145
Hi, on the side anyone know the maker of the winged hubcap on the hubs without spoke? Or yr of hub. Thanks. The hubcap you reference is an aftermarket hubcap. Note the - in the cap and no Chevrolet emblem. For more info on early hubcaps go to my article on the caps in the recent G&D.
Posts: 1,049 |
Gentlemen and Ladies
Anyone know where to gets spokes for these wheels? are front spokes same as rear spokes?
thanks for all of your help fellow members Ken 45145
The best spokesman around is Jim Kanne. (503) 638-5275 jayemkanne@comcast.net He is in West Linn Oregon
Posts: 280 |
Calimerswheelshop.com Located in Southwest PA.
Thanks Woodbutcher
Posts: 1,049 |
Guys and Gals would the tire and rim from a disc fit a spoke rim?
thanks Ken 45145
Yes, but no interchangeability between a 1928 and older. The 1928 is 3" and prior is 2 1/2" rim.
Posts: 27 |
In 1927 were wood wheels standard and disc wheels optional? I was told many years ago that all Canadian cars had wood wheels and US ones had steel discs. All the local cars I have seen around Saskatchewan have had wood wheels. But from the above posts wood wheels must have been available in the US too. Anyone have any knowledge of this?
Depending on the year and the model, generally disc wheels were standard, and wood spoke were available for $25.00, which included the balloon tires for the disc. Specifically, the 1927 cars had the wood spoke wheels as standard on the Roadster, Touring, and Coach. The Coupe, Sedan and Landau had steel disc wheels. The $25.00 option applied to the 1927 also. I am not sure about Canada, however it think it was almost a change of 180 degrees.
