Posts: 35 |
So I gout new park brake cables and they say to reuse the clevis..... How are you suppose to get the old one off the cable and on the new one!? Anyone have any ideas or insight on this mystery? You almost have to be a magician!!
Thanks Noah
Posts: 1,295 Likes: 2
Posts: 1,295 Likes: 2 |
Noah, If it were me i wouldn't fight taking the old clevis off. I would just install a new one.
p.k.
Posts: 35 |
The new on look just like the old on in the pic in the catalog, how do i get it on the cable, i got the old one off cuz i cut it off.....
Noah
Posts: 35 |
I was re-reading my post and it seems a little confusing. I ordered 2 new park brake cables from Chevs of the forties and they say to reuse your old clevis. I took the old cable off and could not see anyway to get the old clevis off. I cheated and cut the old cable to get the clevis off. The problem is there is no way to get the clevis on the new one..... Has anyone done this or have any insight? It seems as if i have to remove the crimped end off put the clevis on and re crimp it but im afraid the end will just pull off.....
I contacted Chevs for advise the first replay was "just thread it off the old one and thread on to the new one... after I replied and said the clevis goes on the other end they replied with "that is all the information I have on this you might have to source information else where".....
Posts: 766 Likes: 1
Posts: 766 Likes: 1 |
Doesn't sound easy to me, either. I'd be checking eBay... :-)
Dale Carter VCCA #8661 1948 Fleetmaster Convertible 1948 RHD Stylemaster Sedan Delivery 1948 1-Ton Tow Truck 1967 Camaro Coupe
Posts: 35 |
END!!
What I have come up with in all my research is to cut the clevis and slide on the cable the pinch the clevis back together. Seem stupid they couldn't just put the clevis on the cable but it works. I also put a little tack weld on it to hold it closed. Thanks for all the replies!!
