Posts: 326 |
I am adding the second horn on my 31 and I discovered that both terminals on the horn are hot[they light my probe light] I also checked the wire to the horn button and it is hot also,I would have thought that grounding to blow the horn the ground side would be dormant.They both blow real good but I can't find a reason for the feedback to the horn button.It is not enough to blow the fuse, It just dosen't seem normal. Any ideas? :confused: :confused: :confused:
woody
Posts: 11,162 |
Ok, that is the way the thing works, the horns are hot, the wire up to the horn button is also hot, the horn button connnects the system to ground to complete the circuit and blow the horns. The horns are above ground.
Posts: 326 |
Thanks guys ,I was not sure and wanted a second opinion.They sound real good as a pair.
woody
