Greetings! Looking for info. on 57 Chevy overdrive transmission solenoid. Was sold a 1116926 NOS solenoid. Bought brackets that appear correct but solenoid does not match brackets. Do I have a good part number? Rebuild manual does not have any photos of the solenoid on the side of the Carter 4 bbl. carb., nor does it mention any adjustments. Was there a service bulletin or any photos or instructions pictured? Do I have the right solenoid? This is for a 220hp.W/ 3spd overdrive.
Joseph Patrick James Kearney
The part number is good for '57 passenger car and 1/2 ton pickup.
I have no knowledge beyond that. Sorry.
Neil
have a nice day
This part 1116926 is referred to as a relay. There is a part # 1998130 called a kickdown switch 4 terminal (carb). Maybe this is what you wanted and you have a relay?
Neil
have a nice day
Thanks for the reply joe
Thank Lucky 1 for4 the reply joeyk3950
