#166869 03/02/10 05:08 PM
p.k. Offline OP
I'm looking for help identifying what i believe to be an early 350 crate motor. I have searched all the books i can find with no luck. The stamp on the engine pad is.
1M06024VP.
Not sure if this number is correct or someone has used a stamp kit on the block. Any information on this engine would be appreciated. driving
p.k.
1956 BEL AIR 2 DOOR HARDTOP
p.k. #167028 03/04/10 07:11 AM
If I read your posting correctly you have listed the serial#. Look for a # cast in probably just above the bellhousing behind the left rear cylinder, this will tell the age and possibly the capacity.
tonyw #167052 03/04/10 10:14 AM
p.k. Offline OP
Tony, the number i posted is stamped on the passenger side head pad. I,ve tried to check the casting number with no luck flashlight, mirrors and so on. It's not real important to me as the car runs perfect. Just a want to know kind of thing. If i ever have to pull the motor I'll know for sure. In my mind i think it's a early 1969 350. Anyway thank you very much for your response. beermugs
p.k.
p.k. #167074 03/04/10 04:07 PM
Originally Posted by p.k.
The stamp on the engine pad is.1M06024VP.
I found a suffix of HP, a 69 full size, 350 with M/T. no VP
Chevrolet
Valve In Head, Ahead In Value
p.k. Offline OP
Just received this information from the chevy talk web site.
Answers some of my questions but not all.
Paul, drink
you do not say what body this engine is in or may have come out of.I show it as a 1969 Chev truck engine(VP code),350-215hp(2bbl) manual- trans.Pretty much a base,low comp engine for a standard pickup of the era.
Hope this helps,Jim
p.k.
p.k. #167175 03/05/10 08:28 PM
Paul, drink
Hope this helps,Jim
Paul,I replied to your question on chevytalk.I occasionally check in over there.I much prefer our club chat here,though.
What else do you want to know? Jim
Paul,
I break down the pad numbers this way:
1-Chevrolet Division/ M-GM's Mexico engine plant/0602-June 2nd/
Finally,could the four be a nine(year)?
Jim
The "crate" engines were made in Mexico. That makes sense.
p.k. Offline OP
Jim, My only other questions are. 1. does this engine have flat or dome type pistons. 2. is it a 2 or four bolt main bearing engine. 3.what would the cc of the heads (70) (76)?
Those are the only remaining things i would like to find out.
I always try here first for answers but sometimes they might get over looked. Like you, I think this is the best chevy club in the world. If you could help with these questions it would be greatly apprecaited.......
p.k.
p.k. #167185 03/05/10 10:10 PM
Paul,
Do a search on "Chevrolet crate engines"...I would bet you can find the info. there.
p.k. Offline OP
Thanks Gene, Never though to do a search on crate engines.
These specs are not a big deal to me as i bought my 56 bel air around 12 years ago with this engine installed.
after all these years and being retired now,I have a yearning to know these things....
parking
p.k.
p.k. #167200 03/06/10 09:48 AM
Sounds better that its in your 1956. I thought it may have been in your Vette.
p.k. Offline OP
No Gene, the vette is 99% stock. The only changes I've made are few chrome dress up things on the engine. It has the
327/300 h.p. but it must be a crate engine also, the head pad has no numbers at all ?
p.k.
p.k. #167205 03/06/10 10:37 AM
My guess would be if there are no numbers on the pad the block only was replaced at one time. When a block was replaced the numbers from the old block were supposed to be stamped on the new block. I am not sure about crate engines but years ago when we ordered a complete engine it was taken off of the assembly line and was stamped, warehoused as a part, and the numbers were stamped into the pad.
Hi Gene,
You are reading my mind!I knew crate/service replacement motors were assembled in Mexico,but was not sure how far back that went.
Thanks,Jim
p.k. #167222 03/06/10 04:21 PM
Paul,
My guess would be standard low perf specs of the era.Flat top pistons,2 bolt mains,76cc heads with 1.72/1.50 valves,9:1 comp,etc... Jim
p.k. Offline OP
Gene, searched crate engines,crate engines from Mexico and nothing went back that far. Jim, Thank you for your time and your help I now have a general idea of what this engine is.
Maybe someday if it breaks i will know for sure, but the way it runs i don't think it will break anytime soon.
( IT'S GOT THE HEART OF A LION )
p.k.
