Posts: 1,136 |
I have acquired an extra '32 motor (194) with 2 transmissions, 1 attached to the motor and 1 separate.
What is the best way to prepare these for some (maybe) long term storage?
Posts: 1,136 |
No ideas????????
1 of the tranny looks like it has been sitting for many years in a garage or shop. The motor with tranny was recently removed.
Should I remove parts from the motor like the carb and store alone or leave on motor, remove plugs and MMO?
I should be able to put it somewhere where I can turn the motor over with the crank every now and then, unless I lose more of my memory.
Posts: 184 |
Do a search on "winter storage" and you will get some hints from other strings on the topic. Hope this helps.
Seeing the USA in a (1930) Chevrolet
Posts: 1,136 |
