#165296 02/13/10 10:49 PM
wawuzit Offline OP
Where can you buy them for a 38 coupe.
wawuzit #165317 02/14/10 12:14 AM
I got mine at Hampton Coach. Do you still have the metal trim that holds the windlace?
Brian
bigbth #165333 02/14/10 04:40 AM
wawuzit Offline OP
Yes...THANK YOU
wawuzit #165354 02/14/10 01:33 PM
When I had the interior put back into my car, I had the Hampten Coach kick panels, but they had been wet at sometime and were warped. My upholster got some new hardboard, sewed a new trim piece around the edges and painted it to match the original color and we put that into the car. Cost of materials was less than $20 and labor to do it was about an hour.
Like so many things, "this ain't rocket science."
Rich
1937 Master Deluxe 4-door Sport Sedan
Restoration project 99% complete
May never get to 100%
RichK #165366 02/14/10 03:52 PM
I went to a local fabric store here in the area and was able to find a piece of hardboard, 3\16-1\4" thick. Used the old panels for patterns and painted them brown.
___________________________________
Joe's 37
Joe's 37 #165369 02/14/10 04:44 PM
The originals out of my 38 were vinyl covered. My upholsterer just recovered them.
Tiny #165374 02/14/10 05:04 PM
wawuzit Offline OP
Your wiring looked like mine. The problem I had was being 6ft and 210 lbs., not to mention 62 yrs old. I couldn't get up under the dash to get to some of the old wiring. Being old isn't all fun. Grin
wawuzit #165376 02/14/10 05:21 PM
i know what you mean... i'm 60, 5'6", 350lbs. but i found that taking out the front seat will get you more room to work under the dash. i was hanging my feet over the seat and a bucket to hold my head up while rewiring the dash...had to get my wife to pull me out... so embarasing.
Ken's 1940 Special Deluxe Sedan
1970 Cadillac Hearse
wawuzit #165391 02/14/10 07:57 PM
Try 6'4" & 300lbs. blush That's why I paid a considerably smaller guy to put the new harness in. laugh
kwchevy1940 #165411 02/14/10 11:38 PM
Mr. KWHITE has it right. I am 63, 6'1" and 180, but I can tell you that taking out the seat makes a huge difference. The front seat is a snap to take out in the '37, I can't say how the other years are, but regardless, it is worth the effort to gain easy access. A couple old blankents add a nice cushion on the floor too.
I also removed the headlight switch and ignition switch when I wired things up. Then, about the only crawling around I had to do was to connect to the back of the instrument panel.
Rich
