#16528 02/04/06 11:56 PM
big D Offline OP
Will 1930 fenders fit on a 29 chev or are they different
#16529 02/05/06 12:00 AM
1929 and 1930 passenger car front and rear fenders are the same for US cars. laugh laugh laugh
#16530 02/05/06 11:04 PM
big D Offline OP
Thanks Junkyard. I found a 1930 and was hoping that some of it would work.Do you know, will the frame work for the 29 as well?
#16531 02/05/06 11:16 PM
Yes! A 1930 bare frame will work, but some of the holes in the frame rails are different and etc. yipp wink laugh laugh
#16532 02/06/06 01:26 AM
Will the trunk lid from a 29 & 30 coupe fit on a '31 coupe. I think I need at least the skin.
#16533 02/06/06 11:28 AM
They are not the same. :( :( :(
#16534 02/06/06 12:32 PM
Actually there are two different trunk lids for '31 Coupes.
#16535 02/06/06 12:38 PM
Correct......notched and un-notched.
laugh laugh laugh
#16536 02/06/06 07:55 PM
Oh Oh Gotta go to the body shop and check it out. stressed
#16537 02/06/06 08:48 PM
Ok, I am in learning mode here. When you say " 1931 Coupe" do you refer to the Job No. 31567 5W Trunk version AND the Job No. 31557 Standard Coupe? Or just one or the other? THEN, when you refer to notched or un-notched, what ,specifically, is the thing that is getting notched or not. By extension, does this apply to the '32 Coupes? Thanks, Bill/KC Wood
All the best, Bill
#16538 02/06/06 11:17 PM
Bill,
Mine is a '31 chev 5 window coupe, Detroit, Mich., Job #31567, Body #J 434, Trim #1, Paint #69, and is a trunk type, not the rumble seat.
Jerry
#16539 02/07/06 01:03 AM
We are referring to the 31557 and 31567 coupe models with the trunk. On the trunk lid with the exposed hinges the top corners of the trunk lid are notched.
laugh laugh laugh
#16540 02/07/06 11:33 AM
Common wisdom (what ever that is) considers the lit with exposed hinges to be the early model that was replaced with the hidden hinge trunk lid. My observation is that the quarter windows (on the 5 window) and rear window on both couples had upholstery instead of a metal molding on the inside if they also had the exposed hinged trunk. That also is considered to be the early models.
#16541 02/07/06 12:00 PM
Thanks Guys,
As this relates to the wood frame I would guess that it would affect both the Deck Upper Crossbar and the Deck Lid Upper Crossbar, in that the hinge mortises would be different. In '32 , did they use the hidden hinge version only? Thanks again, I love learning these details. Bill/ KC Wood
All the best, Bill
#16542 02/07/06 12:20 PM
Yes, in 1932 the trunk lid was not notched.
laugh laugh laugh
