#163570 01/29/10 03:54 PM
61 vert Offline OP
Are there any sources for the glass lens for the oil amd amp gauges in this era car? .045-.050 thick and 1 13/16" across.
what year of car do you have??
I have a 28 with the oval glass lens, but one was cracked.
I was at the local retail store and found some cheap picture frames that had the right sized glass, the bonus was the glass was concaved and added a new look instead of flat glass, and fit with little to none fabrication + look great.
They also had the same frames in flat glass, so you might want to check out some store's.
This is a lot cheaper than haveing them made, I paid about $3.75 per frame in the store, and had them installed in about half an hour.
Just an idea.
Keeping vintage Chevy alive.
61 vert Offline OP
Thanks. I will ck. I ordered a gauge lens from Summit. 2" in diameter and will try sanding it down on my belt sander. Only need to take off 1/16 all the way around.
61vert, The belt sander will work well as long as you don't over heat the class
Listen to the "click'n" of those push rods
61 vert Offline OP
Hope so. I assume the finer the paper the better.
A dremel with a diamond bit and some water work's great if a belt sander is to big for certain jobs.
This work's well on small lens and odd shaped lens config.
