steveo Offline OP
Can someone tell me the correct way to attach the kick panels in a 32. I see they slide into a slot but what holds them in the rear? I was thinking of using small wood scres with finish washers.
In my 31 they were just tacked. On a 32 I restored with a Hampton coach kit I tacked them with a fancy round head black tack that came in the kit. My 31 was factory original when I started.
Dick
The black cardboard kick panels are tacked to the bottom of the door frame post (A pillar post) using black round and domed head tacks. There also should be a 1/4" or so "leatherette" (vinyl) trim that the tacks would go thru at the rear (closest to driver) and next to the frame post.
If I remember correctly, that 1/4" leatherette trim extends up and in between the dashboard edge and the door edge post ending at the bottom of the windshield.
JYD, will know for sure!
Chat Group Chapter Member
Current rides;
1968 Camaro rs/SS 350 4spd
2000 Blazer LT
2005 Malibu Maxx
2007 Acura TDX
Last total restoration;
1932 Sport Coupe
Sounds good to me!
