Posts: 238 |
What year(s) ring & pinion gears will interchange with a 1929 passenger car?
Capt. Harley
Posts: 1,213 Likes: 1
Posts: 1,213 Likes: 1 |
1928 ring and pinion gears are useable,though the '28 ring gear is slightly smaller,but should present no problems with adjustment.Pinion bearings are identical,as well as ring gear carrier bearings.
CJP'S 29
Posts: 238 |
Kevin, Thanks for the info. '28 is the only year that will interchange? :) :confused:
Capt. Harley
Posts: 2,299 Likes: 8
Posts: 2,299 Likes: 8 |
1925-29 ring+pinions will interchage.
