Posts: 2,576 Likes: 2
Posts: 2,576 Likes: 2 |
i've removed all obvious fasteners on the windshield regulator board,mirror and the side garnish mouldings in an attempt to get at and repair the windshield regulator. the board won't come off and i don't want to harm anything as this is new territory for me. can't find anything in archives. thanks guys, mike
Posts: 2,299 Likes: 8
Posts: 2,299 Likes: 8 |
Mike, If i remember correctly there are 2 bolts at either end and 2 wood screws in a center support on top edge.
does the regulator board and the windshield have to come out of the windshield opening together? mike
Posts: 81 |
I think the regulator board is just hanging up because of some wear in the pins that slide in the slot of the widshield frame. Gently, work it free.
The board must come out first, then the windshield must be raised to clear the dash and removed from the bottom. The top of the windshield moves up into a body brace so it must be removed this way.
Hope this is clear, good luck, Mike.
gary: the pins were seized on the windshield frame. little lubricant, gentle prying and the board popped off without my damaging the windshield glass. thanks much. mike
got the regulator out, cleaned and lubricated it. reinstalled it and now the air conditioning works again after a 50 year hibernation. thanks again gary. mike
