Mack, To sell them might be a solution if we all were clear thinking and logical. But as you already know if we all were, then none of us would be in this hobby. Just ask some of your non-car crazy buddies or neighbors. If they are honest they will tell you that all those old, obsolete vehicles just don't make sense. Join the modern world and "text"! don't call or talk? It is also not a matter of "need" even thought we often use that word to justify our lunacy. It is indeed a matter of "want" and that can often be much more powerful than "need". Just ask the druggies or smokers or ???? So if chef wants to put on the Unity the do it. I am sure he will be happier. That is unless he will get a bunch of personal pleasure in spending the time and money to restore and install the Guide (ing) Light.
Posts: 1,295 Likes: 2
Posts: 1,295 Likes: 2 |
Chef: Like chipper said. Do what makes you happy and don't let one or two negative people persuade you differently. Some people think if it's not there way,it's not the right way. Do it your way !
p.k.
Posts: 619 |
Chef. MHO
I was in the EXACT same position you are in right now!
My brand new 5" unity has been sitting on a shelf for the last 7 years, while my not so perfect S-16 has been on my car car for the last 5 years. If your a PURIST?
Good luck???
Posts: 3,578 |
As you can see from this thread I am taking this installation very slow....Yes a very big step drilling a 1/2 inch hole into a classic car...Crazy yes but cautious,very much so.I have made many expensive mistakes on the 48 over the years and many of those much smaller a task.. After Ray mentioned the clearance issue I made a dummy light out of a 6" styrofom ball and 1/2 dowel and found that would not be an issue...The big thing though is the drill landing perfectly in the right location inside the car.It appears to me there is NO! room for error or MUCH damage could occur,not to add there are several wires running through that pillar...Haven't pulled the trigger,but on this car the light would sure fit the bill...I would add in some peoples eyes the Guide light is close to show quality,but I am more picky then most...After I make the choice of what light to install no turning back
Short of the crusher, nearly any mistake can be fixed. Some are more expensive than others. Of course it was a wiser person than me that said "measure twice, cut once".
Posts: 11,162 |
Well Chef you did ask for opinions....... Do you see this spotlight? I never ever needed it except at the drive in movie pre-dusk follow the ball film. The damned handle and switch was always in the way.....You don't follow much with a spotlight at 70-80 MPH....I hated the damn thing but never decided to weld the hole up, lead it in and spray primer and paint, so it stayed on the car ![[Linked Image from pic100.picturetrail.com]](http://pic100.picturetrail.com/VOL1180/4341552/9153654/276341437.jpg)
Posts: 3,578 |
Well Mack the 48 does'nt quite meet those speeds and the big old steering wheel is in the way most all the time any way...chef
Posts: 3,578 |
Well I took the leap and drilled the holes for the guild light myself!!Yes I was successful  I had many concerns about the templates placement,but fortunately I didn't hit the dash,door or WINDOW  ...The antenna and king bee mirror are free from any danger but I am planning to go to a peep mirror on the rain deflector (a little too much going on in that area now)...So in search of another accessory if anyone can help???As for the plating on the guide light,I am a little anal and with out my reading glasses it looks perfect....So who would like to borrow my 1/2" drill
Posts: 2,433 |
Congratulations Chef!!!!!!  We knew you could do it  Scary stuff, huh!!!!! Just looked at your email Chef........tomorrow I will have a little time to upload those pictures to Photobucket and I will post them here. Great job Bruce.
ken48 VCCA 42589
Posts: 619 |
Way to go chef!!!!!!!!!!!
I knew you could do it..
CONGRATULATIONS!!!!!!!!!!!
Bet it looks SWEET!
Posts: 837 |
I’m glad your installation turned out for the good Bruce. I’ve been following this thread with some interest because I’ve got a botched installation of a Guide S-16 on my 1950, 3600 pu. http://www.pbase.com/dennygraham/accessories&page=2 I’m getting into the bodywork a little at a time and the cabs number should come up this fall after the summer driving season is over. When I bought the truck it had this spotlight mounted on it but the guy that installed it must have been as tilted as the guy that painted the truck red. As you can see by the bend in the thru tube that he drilled the hole crooked. My guess is he drilled half way from the outside then decided to go the other half from the inside and the two holes didn’t line up. Then either the trim/mounting plate was the wrong one or he just didn’t know how to mount it. I’m going to be welding up holes and re-drilling when I get to the cab and I’d really like to see some pictures of the correct installation so I can do it right the second time. I read a comment on the brightness of the 6v bulb. I just have to voice my feelings about a 6v bulb being just as bright as a 12v bulb or a 24v or a 120v. No matter what the voltage of the bulb is, bulbs of the same candlepower will be just as bright. It is simply a matter of how much current your system is drawing, the increase in voltages just allowed for lower current draw, lighter gauge wire meaning less copper in the loom, less expense, less weight. Dim 6v lights are almost always caused by high resistance connections, i.e., corroded crimp or push connectors, corroded contacts, poor ground return connections etc. Much of the lighting is grounded to the sheet metal which is grounded to the frame thru bolts or screws which will corrode after sitting out in the rain or in damp garages for 40, 50, 60 years. So if your 6v system has good electrical continuity then you’re going to have good lights, certainly adequate for any of your driving needs. I guarantee you that 55 years ago we weren’t driving around in the dark with dim lights. The improvements in lighting are not from the increase in voltage but from the filament, gas and reflector advances that have been made over the years. Denny Graham Sandwich, IL
Denny, Your comments on light bulbs is right on and should be read by everyone that is contemplating changing to 12volts. There are way too many people that believe that 6volt systems were inferior in performance and that is why they were replaced by 12 volts. The truth is that it was an economical decision by the car companies. They also had the option to go to the "standard" military, telephone and aircraft voltage of 24volts but opted for 12volts primarily because somewhere between 12-36volts DC can be fatal if a person is well grounded and contacts a "live" wire. DC is fatal at a lower voltage than AC. Before someone comments I know it is the amperage that kills but voltage that controls the quality of the connection. (The higher the voltage the better the connection.)
Posts: 865 |
A couple of comments on spotlight installation. I have had experience with installing spotlights on police cars at the assembley plant.All spotlight holes were drilled from the outside with a special built jig. The jig had locating tabs and was clamped in place. The jig had a four inch guide sleeve with a half inch inside diameter hole, the same size as the drill bit.The guide sleeve was to insure that the drill bit was at the same angle for each hole that was drilled and did not let the drill bit flex. Precautions still had to be taken once the drill bit cut through the first layer of metal and entered the cavity in the pillar. The bit had to be allowed to cut its own path. If the bit was forced against the uneven metal on the inside of the pillar it would flex and cause a crooked hole. In some instances where a hole needed to be drilled and the jig was not available the outside spotlight bracket was mounted in the correct location and a portable four inch guide sleeve was mounted in the bracket and the hole was drilled, usually with good results.
DD
Posts: 3,578 |
I feel very lucky this time and yes when getting to the interior pillar section the drill wanted to move around...I did use a bit with a pilot on it which helped some once inside..I was also very worried about hitting the wiring
Posts: 4,951 |
Hey Bruce,
Congrats!!! I'll tip a maitai this afternoon in your honor. Only a few more days and then back to the cold rain. Arrrrgh....
Bill.
Posts: 3,578 |
Man Bill we thought you had found another Woodie in Hawaii and weren't coming back
Posts: 2,433 |
OK guys.......here are a few pictures of the long awaited spotlight on chef chevy's great looking 48 Aero.... ![[Linked Image from i100.photobucket.com]](http://i100.photobucket.com/albums/m11/48fleetline/ChefChevySpotlight2.jpg) ![[Linked Image from i100.photobucket.com]](http://i100.photobucket.com/albums/m11/48fleetline/ChefChevySpotlight1.jpg) ![[Linked Image from i100.photobucket.com]](http://i100.photobucket.com/albums/m11/48fleetline/ChefChevySpotlight3.jpg) I think Bruce did a fabulous job  and deserves a  PS....Hey Bruce, great looking clock
ken48 VCCA 42589
Posts: 837 |
Thanks for posting those pictures Ken, that’s one beautiful automobile he has there. I’m gonna add those pix’s to the others I have of that body style. If you could post a link to your Photobucket Bruce, I’d like to see more pictures of your ’48. My first car back in ’57 was a charcoal gray ”˜41 Caddy fast back and I drool over cars like Bruce’s every time I see one since the bodies were so similar. A ’41 Caddy in any condition is WAY out of my price range today, but I may be able to swing a post war Chevy Fleetline that’s in need of a few years work when I finish up my ’50, 3600. Thanks Dan, That’s kind of what I was thinking about doing when I re-drill my pillar. I have a pretty decent machine shop in the barn and I thought it may be a good idea to make a fixture up. I doubt if I will ever be able to find an original outer trim piece so I think I may need to make a new one for the pickup. The outer trim piece should be installed parallel to the pillar like in the pictures of Bruce’s installation. I’d still like to see a picture of the correct outer trim piece on an AD pickup so I could get the profile correct. I have a sneaking suspicion that the unit that’s on my truck may have been for some other vehicle, maybe off a car and that’s why they boogered up the installation so bad the first time. And it’s obvious that they didn’t use a fixture with a drill bushing or for that matter any sort of guide at all. Denny Graham Sandwich, IL
Posts: 3,578 |
Denny,its kinda all about location so the use of the template provided with the instructions is the key.So if you need a copy let me know ...Thanks for the pics Ken,why I don't get set up on photo bucket or something similar???????Some day
Posts: 2,433 |
Thanks for the pics Ken,why I don't get set up on photo bucket or something similar???????Some day Hey Bruce, if you can install that spotlight without wrecking something.......you just might be able to set up a Photbucket account too  Otherwise I don't mind posting for you. Denny....there are a couple more pics of Bruce's Aero in the VCCA Members Photos...just search back a way. And if you get despsrate. my 48 Aero is the one in the 100 Years Of Chevrolet from the VCCA homepage and another view in my signature.
ken48 VCCA 42589
Posts: 837 |
Afraid the template for the pick up would be different than the cars Bruce. I think the pillar sits a lot more vertical on the PU. I've had all 6 pictures of your Fleetline saved for a while Ken. If it weren't for the front clip from the side that looks just like my old Caddy. Although I'm tied up with the truck for a while, I’ve been keeping my eyes open for a car; I'd like something post war but my wife is drawn toward the early 50's style. Since I already had a few of them when I was a teenager and they would be my second choice. I can see a battle on the horizon when it comes to laying down the money. But I gotta finish the AD first and right now doing it all myself, I’m a ways off. http://www.pbase.com/dennygraham/image/120846432/large Thanks for all the pictures guys; I'm building quite a photo album of your rides. Denny Graham Sandwich, IL
Posts: 3,578 |
![[Linked Image from i563.photobucket.com]](http://i563.photobucket.com/albums/ss79/chefchevy/guide2.jpg) Here is few close ups
Posts: 3,578 |
Posts: 3,578 |
![[Linked Image from i563.photobucket.com]](http://i563.photobucket.com/albums/ss79/chefchevy/guide4.jpg) Well this is my first attempt at photo bucket  Ken
Posts: 2,433 |
Ya done good Buddy!!!!
ken48 VCCA 42589
