Thrasher, When I replaced my battery cables last year, the end of the grounding cable, from the battery, went to a 3/8" hole at the 2-o-clock position on the, right side about mid way, on the transmission. I think I used either a 1/2" or a 3/4" length 3/8" bolt on that. Make sure to, sand or scrape, this area clean of paint or rust first so you have a good ground. I also ran another ground strap from, one of the starter mount bolts, to the frame. There agin, make sure to clean all contact points,of paint and rust. Hope this helps.
_____________________________
Joe's 37
