Posts: 3,578 |
If I am correct the original cable for the 48 is a flat strap If I convert to a big 4-O cable for a better ground how will this effect judging??Should I wrap it a more original cloth material?
The original grond cable was a woven flat strap. If you can locate one that is of the same size as the original it will work just fine. I am sure that they are readily available. Points would be deducted for an insulated cable.
Posts: 3,578 |
I am presently using the flat strap as stated above After all the discuss about the big ground cables I purchassed 3 ft of 4/0 cable and it is about 3 time the weight compared to the strap...I guess I will leave it as is.
Posts: 762 |
If you don't plan having it judged then it would not make any differance.
