langer Offline OP
The other day I was reading the blog and someone said to make sure you use Locktite on the threads of the bolts when putting them back together. I then went online and looked at the locktite and saw there are a bunch of choices when it comes to their products. Any suggestions as to what should be used specifically? I am beginning to put a 29 back together from ground up and could sure use any suggestions from those that have done this before.
Thanks.
Erik Langhofer
Phoenix, Az.
I use blue on everything that needs holding. Red is more permanent and will require heat and/or some extreme oomph to remove. My oldest son is a licensed mechanic and also uses blue on all the cars he fixes.
It's not how fast you can go, but how good you look at 20 MPH.
