#157362 11/23/09 05:40 PM
neemot Offline OP
I was reading an old chat on condensors for 6-volts and junkyard dog said to use a NAPA #DR-70. That may be a good # for the stores in the NW but our store in TN doesn't have a listing like that. Their book says to use a #RR174, says its good from 35 thru 62. I'm confussed. Am I beyond help?
Use the one they suggested.
devil Agrin
Agree - when last available from GM the same condenser was used from 1933 throgh 1962.
The DR-70 is the number for the Standard Motor Products condenser, and the RR 174 is the number for a NAPA condenser. The applications for both are about the same.
By the way, in my two old postings regarding the condenser I never said that the DR-70 was a NAPA number. Here is what I posted:
"On the condenser, try a DR-70."
"The DR-60 or the DR-70 condenser will work also. The only difference between the two is the length of the lead, and the microfarads are correct as well."
neemot Offline OP
Thanks for the help guys. I bought the RR174 but am not ready to try to start it yet. The truck hasn't ran in years and the more I work with it the more unsure I am that it ever will again. I've cleaned up the starter and ofcourse have sprayed a lot of WD40 in the cylinders but even with a 12 volt battery and the spark plugs out it cranks over really slow. I have never tried to bring one this old back to life.
And for Junk Yard Dog. Don't get your fender skirts in a wad. Just because I'm old don't mean I'm smart. What you said was:
"Go to a NAPA store and purchase a DR-70"
I should have known that was a Standard Motor Products part #. I guess I put 2 + 2 together and got 5. Anyway, I DO appreciate all of your help and information.
You are correct! That was posted in a different old thread than the one that I looked up. We have had several discussions in different threads on the condensers in the past.
At any rate, I get all of my DR-70 condensers from my local NAPA store. While the DR-70 is not a NAPA number, they do order Standard Products parts for me fairly often. I just go in there with the Standard Products number that I need to purchase and they order it for me. I have tried having them look up the corresponding part in a NAPA number but half the time the counterman can't find the listing so it is easier if I just give them the Standard Products number instead and they order it.
neemot Offline OP
What do you think about the slow cranking problem I mentioned ..or .. should I open a new thread on that one.
The slow cranking could be one of several problems. I would suspect a little rust in a cylinder or two. Tight valves could be another. I would not worry too much about it unless it rolls over so slowly that it will not start. Just make sure that everything that moves is lubricated.
