#157207 11/21/09 07:09 PM
While I have adjusted valves many times I always wonder how I have done on the job. It seems that the amount of drag on the feeler strip determines the result. It must be an art and only experience helps one learn. If you tell me a light drag on the feeler it is so subjective that my result would differ from some one else. I guess I would need an expert to do the job and then feel their work. And experts are rare.
The basic rule is that the valves are better off by being too wide rather than too close. With that criteria, I would set the valves when the clearance allows the feeler gage to enter easily and come out with some or no drag.
devil Agrin
LooseRocker.
To ease your mind, you might try the go-no-go method. If clearance calls for .010, set it at that and than try a .011 guage. If that goes through, than its too loose, but if it doesn't go, than you have it set at .010.
I have done it this way for years and love the results, especially for my pea brain. Good luck.
Jim.
LooseRocker
Ray is correct, a little valve chatter is much better than burnt out valves.
The slight drag is an acquired feel though.
If the feeler gage blade looks like something tried to eat it, then the valve is to tight. When I purchased my first car a neat 38 trwo door it ran very quiet, by the time I had owned the car a week and with my lead foot style of driving I had burned exhaust valves as they were set way to tight. I had the head rebuilt, the mechanic told me to set exhaust valves .o1 to .02 looser than spec. Never have had a burned valve since. talk
glyn #157356 11/23/09 03:46 PM
I found that if the feeler gauge comes out with dimples in it the rocker arms are worn into the valve stems (a half moon shape) and the rockers need to be dressed on a bench grinder fine stone or a belt grinder (220 grit belt) or replaced with new smooth ones.
When I owned a gunshop I would build up the rocker arms valve stem ends with nickle steel rod using an acc. gas torch then finish dressing them down with my verticle belt metal sander. Any more I buy rockers at swap meets and keep them for when I need them.
MrMack #157399 11/24/09 12:56 AM
Ray is right, they are way better on the loose side and MrMack is right too, you can't do a decent job of setting the clearance if the rocker arms have wear from contacting the valve stems. I have always thought that the chevy specs were a little on the tight side for high speed driving, especially the exhaust valves.
Ed
