#156293 11/10/09 12:32 AM
Need help with wiring for fuel sending unit. as to which lead is for the sending unit and which is for the hot lead. I know that one post is larger dia. than the other, I just have no original wiring and want to wire with new type wires?
1940century
Here's a diagram for a '38. The 37 should be close if not identical.
I dont think you can hurt it hooking it up wrong as it will work backwards.
VCCA #45194
