#156271 11/09/09 10:03 PM
[Linked Image from home.comcast.net]
thanks Ken 45145
I have a 1927 Chevy Capital AA 4 Door also a 1927 Chevy Touring car, a 1936 Chevy 1/2 ton and a 2010 Corvette LT3 Convertible and a 1953 Packard Caribbean. My tow car is a 2011 Suburban.
Ken - these are covers for the metal stems on inner tubes so equipped with metal stems, which are threaded all the way down to the base. I think they were originally nickle plated.
Roger
So were this originally installed on early chevrolets? I have some of these as well in my collection of parts. I thought they were some sort of a small screw driver handle or something.
Those valve stem covers were used on all early models at least up to 1928. There are several different styles depending on year. Wish I had an accurate list with pictures for what was used each year. Only know a few.
Gosh
you guys are great!!!!!!!
I now know!
thanks
Ken 45145 bigl
Thanks for the info. I almost threw them in the garbage when I was going through all the parts for my car!! Good thing I have difficulty throwing anything away!
Those nice pieces are used on both T-F**Ds and 490 from 1916 and up. Solan finds them posh and is very proud of his 4 wheels with the longstemmed, tube valves and nickelplated covers. He even have some spares if someone pinch one. You have to order more expensive inner tubes with longstemmed valves if you want such covers to be used on the old ones.
They are still easy to get from Snyder and other F**D-suppliers, but the original ones are the best in Solan's opinion!
:vcca:
Here is Solan showing the right front wheel with the valve cover easily seen (at six o'clock):
[Linked Image from img121.imageshack.us]
By solan1916
Solan G, # 32797
Solan
thanks for the wonderful pic,
Ken 45145
Thanks a lot, Ken. I thought I had some closer pictures but could find only this one on the PC:
[Linked Image from img63.imageshack.us]
By solan1916
( 9 o'clock) drink yipp
Solan G, # 32797
Solan
it is possible to see if you zoom in, you see it well.
Solan, by the way what is the gear on that spindle I never saw that before?
thanks again
Ken 45145
You are looking at the speedometer hose with wire to the optional Stewart-Warner speedometer (in miles) on the dash board.
But try to guess what is the material in the small wheel connected to the wire in the hose, and driven by the left front wheel? HD-drivers from same period will know the answer.
chevy luv2 dance
Solan G, # 32797
Solan
OK I am ready to find out.
thanks
Ken 45145 :vcca:
Want to guess vegetable fiber?
Sorry, but you have to make another guess. Try again.
:vcca:
Solan G, # 32797
Solan
anything to do with hydraulics and adjustment ?
Ken 45145
Solan,
Have you ever replaced the fiber gear? Just wondering how long they last, in miles.
Gary
The small cogwheel (to the right) has nothing to do with (syntetic) fibre or hydraulic. It is most probably the original one from long ago as it is made of same material as the similar wheel on a H-D MC. same year. So still no need for a replacement cogwheel on my car after nearly 100 years.
The cogwheel is colored near black because of oil/dirt, but has a complete different color when new.
More suggestions would be nice to receive, folks.
chevy idea
Solan G, # 32797
The gear wheels could possibly be old style grey fibre(similar to the red fibre gasket material)or possibly very well tanned and hardened leather?
idea
CJP'S 29
Very nice suggestion, CJP's 29. Congratulations!
The correct reply is:
The material of the cogwheel is brown, very well tanned and hardened ox leather. It works excellent.
By using leather (instead of metal) the noice was reduced to low or none when driving.
yipp
:vcca:
Solan G, # 32797
Hey Solan
I am going to come to Oslo and make you take me for a ride in that beauty, I will listen for the speedo noise.
Happy holidays
Ken 45145
Looking forward to your visit, but you need to come in the period from May to October. I have been told I should worry more for the noises coming from the turning engine and drive line, than the cogwheel.
But it is nice to know that such a wheel is still working without any trouble.
driving yipp
Solan G, # 32797
As you can see from the picture below, the T-F******Ds also had similar or equal cogwheel as the 490s:
[Linked Image from img211.imageshack.us]
By solan1916
:vcca:
Solan G, # 32797
