Got a Muncie M 20 trans. Before installing it I decided to take a look inside to make sure all looked good. Think I could of let well enough alone and just install it, But Billy Just Dont Do That. The shifter seals look leaky anyhow, so i removed the cover. Heard a clunk and the cover came, leaving the shifter forks out of place but in the case. First question after I replace the seals how do I put the cover back on and get the Long (i want to call them flat gears) on the cover in the right place? Did I mention that I dont know what gear it is in ? Next since im there I might as well see what ican screw up by replacing the front seal also.I see a retainer of some kind around the bolts.I figure I cant get in trouble with the rear seal. Besides that the trans looks great, no metal shvings, little dust on the magnet, thats it. Thanks guys
