Posts: 194 |
Will a 1933 Master cylinder head work on a 1931 motor? If so what, if anything else, will need to be changed to make it work? Any help would be appreciated.
Rich James
This has been discussed here some time back. I believe the answer was you need to use the 1933 valves, rocker arms and push rods, and head bolts.
Posts: 341 Likes: 3
Posts: 341 Likes: 3 |
The 1933 Master cylinder head will physically fit on a 1931 cylinder block. The cylinder head gasket is the same 29-33. The 1933 cylinder head is approximately 3/16 inch thicker or higher that the 1929, 1930-31 and 1932 heads. Hence the valves and pushrods are longer for 33 compared to 32 to keep the rocker arm geometry correct. To install a complete head, the head bolts, rocker arms, push rods and side cover would have to be used from a 1933 engine to make a 33 head fit on a 29-32 engine block. This is also noted in the Hollander manual. I would also make sure the head bolts do not bottom out in the block just to be on the safe side. The reason I know this is that I am in the process of rebuilding a 29 cylinder head, a 1933 cylinder head and have a junk 29 and 32 head.
Posts: 194 |
Thanks Gene and Bob. My friend has a 31 and can't find a good head to rebuild. He may decide to go with the 33 head. Rich James
Rich James
Posts: 2,418 |
There should be some offers from time to time in G&D where engine heads to 1931 are available.
I think Grady Cox? would be one of the sellers.
:vcca:
Solan G, # 32797
Posts: 194 |
Thanks Solan, I will check with my friend and tell him about Grady. Rich James
Rich James
