Posts: 104 |
What size is the radiator fitting for the transmission cooling lines . I have a 69 C10 with a 350. Its a revers flare fitting but cannot find any tubing to fit it.
Posts: 1,194 |
Is it possible that the radiator has pipe threads? Then you would need a pipe thread to inverted flare adapter.
Posts: 6,149 Likes: 42
Posts: 6,149 Likes: 42 |
Don is right, a lot of radiators have pipe thread fittings as fixtures that require an adapter to suit the pipe end. Tony
