#15285 10/20/05 07:39 PM
The car (32 special sedan) is not sitting level. The front axle is the same height on both R and L sides. The height of front spring perches are 1/2 inch higher on the left that on the right. The same is true for the rear spring perches. Can anybody explain what would cause this?
#15286 10/20/05 08:13 PM
Weak leaf spring.
#15287 10/20/05 09:41 PM
They can be re-arched
FDNY
#15288 10/20/05 10:23 PM
Or.......they can be replaced with new springs as well. laugh laugh laugh
#15289 10/20/05 10:23 PM
con bob, i had my rear springs re arched for about $350, it took 1 day and she sits level and proud now; drives straight now too. the left side was 1 1/4 " lower than the right. the ride is so much smoother now. worth every penny! jim, '30 coupe.
the chevy 6 clatter means nothings the matter.
jf lewis
#15290 10/20/05 10:43 PM
Mr JD. What is a source for new leaf springs?
#15291 10/20/05 11:24 PM
There are several sources. For one of them, go here: http://www.eatonsprings.com/
laugh laugh laugh
#15292 10/20/05 11:40 PM
People kept telling me that my 31 was listing to one side but every time I got out to check, it looked fine to me.
I don't think these people are on the level!!!
JOHN GILL
#15293 10/21/05 12:11 PM
xxx Offline
Get someone (same size as you) to drive your car and you follow behind it to check it out or are you pulling my leg (again) John?
#15294 10/21/05 12:19 PM
Gator: I think he is pulling your leg! wink laugh laugh laugh
#15295 10/21/05 12:55 PM
xxx Offline
You never know with John, he's tricky...LOL
