#152425 09/13/09 02:19 AM
I would like to find a current color match for my 33 master. The original paint was ditz-lac IM-1468. I would like to paint it with a Urethane single stage paint in the same color. A current paint chip formula would be great!!
Thanks,
Spun Rod
I have color chip for the color but no way to compare it to modern paints as our local paint store closed a couple of years ago. If you go to www.autocolorlibrary.com you should be able to buy a single stage urethane from them. Or order a small amount and take it to a local supplier to make the paint you want. I cannot verify that their colors are 100% matches but it is the best available to the vast majority of people.
