Posts: 33 |
Hello -- Can someone out there please tell me how to remove the air cleaner on a 1930 Chevrolet truck? It has to be simple. I've tried but I don't want to break anything. Thank you.
Posts: 33 |
Thanks, Junkyard Dog. I followed your directions and it came right off. I planned to clean the copper filter element with gasoline, as the owner's manual says, but there was no filter material inside at all -- just a hollow shell. Is there a way to add filter material, or should I try to find a unit with a filter already inside?
Posts: 3,542 |
Do a Chatter search of 'air cleaner' or similar words and you should get a few strings here with suggestions/comments about your air cleaner.
Posts: 33 |
That's good news. Thanks, guys.
Posts: 2,576 Likes: 2
Posts: 2,576 Likes: 2 |
dawg: was the copper mesh element inside a 31 aircleaner natural color or was the whole deal painted/dipped to get the black finish on the air cleaner main body?if it was pinted/dipped, i'd suspect some or a lot of black overspray/dip on the copper mesh.mike
do you think the mfgr painted the individual stamped steel components, inserted the copper mesh, then crimped the components together? if that were the case, i'd expect the crimping process to scratch the black paint, at least the way my feeble methods would do it.mike
that makes sense. i'll do it the same way. thanks, mike
