#15147 10/16/05 12:18 AM
A friend of mine has an engine he beleaves is a 31 . here is the number he got off the block 835409 My books are still packed so i am not sure if it is or not. can anyone let me know?
These ain't for old guys any more.
#15148 10/16/05 01:51 AM
my book lists 836409 as a '31 . no listing for a 835409 though.
'40 - 1/2 ton , daily driver.
[Linked Image from i60.tinypic.com]
#15149 10/16/05 06:55 AM
There should be a number like A 22 31 on the block. This would be January 22 1931.
The letter is the month, then date, then year.
See you down the Back Roads
Joined VCCA June 1, 1961
#15150 10/16/05 11:29 PM
I'll have him double check the numbers. his shed doesn't have that good of light.
#15151 10/17/05 10:52 PM
Back Roads,
I believe your casting date example should read A 22 1. Only the last digit of the year is given. If you don't know the age within a decade, you are out of luck.
#15152 10/17/05 11:23 PM
Thanks for the help. Its definatly a 31. I will have to go look at it and for the right price maybe i'll have a spare motor. whats a good price to pay for a complete carb to pan 31 engine/tranny also.
#15153 10/18/05 10:01 AM
Somewhere between $ 50 to $ 2500 depending on its condition. If head is cracked (many are), the rods and mains need replacing, the carb is junk and there are small rust holes in the oilpan then $ 50 is about right. Yes that includes if it turns over. If recently rebuilt by a qualified person then $ 2500 might be a bargain. I typically pay from $ 100 to $ 500 depending on apparent condition. The only one that I got burned on was the only one that I paid $ 500 for engine, trans, rear-end. It was "rebuilt" by an aircraft mechanic (for an large airline) who did not know what he was doing. Looked real good but lower end was shot.
#15154 10/18/05 10:10 AM
A $50 engine makes a good trot line weight.
#15155 10/18/05 10:43 AM
"trot line" Macky Wacky? :confused: :confused: :confused:
#15156 10/18/05 10:50 AM
think he means trout line?..
ok epi
#15157 10/18/05 10:55 AM
Could be.......but with Macky Wacky ya never know what he means. :eek: bigl bigl bigl bigl
#15158 10/18/05 11:13 AM
well then, maybe he did mean trot line...the engine is dragged behind a racehorse in training to help it build leg strength?.. laugh
ok epi
#15159 10/18/05 11:48 AM
Well.......with Macky Wacky's bad spelling and crazy postings....that could be exactly what he means! :eek: wink bigl bigl bigl bigl
#15160 10/18/05 01:03 PM
Actually, for a change, MM got it right, except it is one word "trotline".
If you don't know what it means, there is just no hope for you. Look it up in your Funk & Wagnals.
Agrin
#15161 10/18/05 01:41 PM
hey ray,
I hate to sound crabby, but the whole thing sounds fishy to me...
ok epi
#15162 10/18/05 02:55 PM
The A 22 31 means nothing for positive ID....If it was a replacement block cast in 1933 could have B 16 33 for a casting date but still have the 835409 casting number.
#15163 10/18/05 04:38 PM
Thanks for the info. I guess it turns over, so thats a good sign. i'll let you know what happens with the motor.
#15164 10/18/05 07:49 PM
I stand corrected hrndog & Gene. I typed before I thought it through.
See you down the back roads.
#15165 10/19/05 02:24 PM
No!.... it ain't no damn Trout line, it is a damn TROTLINE like you put out in a lake or river with hooks dangleing off and baited to catch Catfish!!!... DUHHH..... some of those Left Coast guys don't know trout from trot!!!!!!!
mad mad mad laugh laugh wink :p
#15166 10/19/05 07:47 PM
Ain!t them used by RED-NECKS ?
bigl bigl bigl
woody
#15167 10/19/05 11:44 PM
"DUHHH..... some of those Left Coast guys don't know trout from trot!!!!!!!"
Well....if some of you Texas dudes would learn how to spell then the rest of us would know what you are talking about. There is a big difference between "trot line" and "trotline"! DUH!! wink laugh laugh bigl bigl bigl
#15168 10/20/05 12:53 AM
Well,I sertainly resemble that last diggin remarke by an an ol allerate flee bittin Mutt.
if you don't know the difference between Trout and Trot you don't know nuttin about catchin' any Channel Catfish.... DUUGUH!
Well anyway here's how you do it..., you tie a $50 engine block on each end of a 200' heavy line, put em' in the Lone Star fishing boat drive out to the Channel,drop one of the blocks on one side of the lake channel, put a bleach bottle float about 10 feet from the sunk engine block and then dangle big old hooks every three feet baited with cut shad, then at 10 feet from the other end tie on another bleach jug and have your big red-neck partner toss the other engine block over the side of the boat, then as soon as you both get back in the boat, and bail it out and just hope you can get away before the game warden wants to see your fishing license..... Next morning before daylight, you "run" the TROTLINE and take the big catfishes home and clean and fillete them for a big fish fry!....At least that is how we do it down here in Comanche County Texas.....
We have a lot of spaces around here, so I u se mor e than some of yo u that are hem med in a long the lef t coast!... between the devil and the deep blue sea.
bigl laugh :p dance wink
#15169 10/20/05 02:45 AM
Ah!, what memories. We kept the family in fish by setting "trotlines". If you kept the number of drop lines down, the warden did not bother you. After the trotline was set and baited we proceeded to the shallow water and picked up a few catfish and bass by 'gigging'. The 'gig' was made from a car spring. Usually gigged a few frogs too. When cooking the frog legs they sometimes kicked the lid off the skillet. At the same time the remainder of the frog was still croaking outside the window. Ran the trotline at day break. If you left it too long the turtles and gar would eat up your catch. "The good ole days?"
Agrin
#15170 10/20/05 09:47 AM
Hum.......sounds like you dudes are from Texas and Arkansas respectively. Out here on the west coast we use the old engine blocks for boat anchors instead! :eek: wink bigl bigl bigl
#15171 10/20/05 10:23 AM
macky,
bigl bigl bigl
ok epi
