I am replying to the original question. I have a '51 3/4 ton and added a sway bar at the same time I did a lot of front chassis work to the truck including a set of them thar radio tars.
Prior to all the chassis work, my old motto was "give me a groove and I'll follow it".
![[Linked Image from oldgmctrucks.com]](http://www.oldgmctrucks.com/smilies/eee.gif)
Following new king pins, new shocks, new Moog 26L&26R tie rod ends on a
stock original 47-54 1 ton tie rod, and the installation of an aftermarket sway bar with custom brackets (GMC front cross member is different from Chevy), my truck handles like a sports car at all speeds.
![[Linked Image from oldgmctrucks.com]](http://www.oldgmctrucks.com/smilies/icon_smile_big.gif)
Each component gave a little improvement, but the two largest single factors affecting handling on my 3/4 ton were radials and the sway bar. To me, on the 3/4 ton it was profound.
These trucks, when driven on modern roads, average a lot faster speed than they were originally designed to go. Limited access highways push those up even higher and the high center of gravity cabs will take a lean set on a corner like a cloverleaf style ramp, or even going around a long turn on a highway. When you come out of the turn the return response in the steering from cab roll is pretty pronounced. Front sway bars eliminate that.
Here's a slide show to the work I did on my 3/4 ton and it was a
very significant handling difference.
http://rides.webshots.com/slideshow/353293942FmhAXv![[Linked Image from inlinethumb41.webshots.com]](http://inlinethumb41.webshots.com/45608/1355469168030786630S600x600Q85.jpg)
As far as this 3/4 ton owner is concerned, sway bars are a no-brainer. There is no downside to this at all with the sole exception of your time, and your wallet.
If you are going for a trophy for originality, you might lose a few points to some judge whose hanging on too tight. If you want to drive your truck and enjoy it more, put the sway bar on it and slap some radials on there at the same time and you will be astounded at the difference.
Anybody that sees me at a show or anywhere and wants to take my truck for a ride to see for themselves on this is more than welcome any time to slide in behind the driver's seat and go for a spin.
I drove this in a 2007 Cannonball Run from Boston to San Francisco and topped Pikes Peak, Mt. Washington, and the Redwood Highway along the way. Trust me going up and down those highest auto roads in the East & West and then the Redwood Highway gave it all the steering testing possible in a 5,000 mile run. The sway bar is worth the time and effort.
