Posts: 1,049 |
Hi Guys is there an R-O for carter brass bowl 23-24 or is this RXO I thought RBO only one before RXO straighten me out please Ken 45145
I have a 1927 Chevy Capital AA 4 Door also a 1927 Chevy Touring car, a 1936 Chevy 1/2 ton and a 2010 Corvette LT3 Convertible and a 1953 Packard Caribbean. My tow car is a 2011 Suburban.
The Zenith was used for the very early 1925 cars. Then the switch was made to the RXO. At about the same time the vacuum tank was changed from the G&G to the 8 bolt SW.
I don't understand your question. Please ask it in another way.
Posts: 1,049 |
Hi Guys is there an R-O carter brass bowl 23-24 or is this RXO, I thought RBO only one before RXO straighten me out please Ken 45145
Posts: 1,049 |
Junkyard Dog thank you very much for your help. I have been told by people who know more than I do about it that Chevy went RB-O RX-O RAJX-O RAKX-O and RJH-O8.
Thank You Ken 45145
Ken Your list is correct. The dog's answer was not. The carburetor number 33s and 32s carburetors used a RB-0 casting. The carburetor number 4s and 6s used the RX-0 or CRX-0 casting. As pointed out in an article in the G&D it is indeed interesting that carburetor numbers 33s and 32s were use by Chevrolet before numbers 4s and 6s.
Up to 1922 carburetors were supplied by Zenith (except for a few early models that used Marvel, Stromberg carbs. Starting apparently (definitive documentation on the exact dates has not yet been discovered) in 1922 Zenith, Carter and Holley carburetors were factory installed. ca 1925 model year Carter carburetors were factory installed. It is possible that some "early" '25 models (Superior K) had factory Zenith or Holley carburetors. Carter carbs were exclusively used from then to 1949.
The R-0 Carter carburetor was used by 1925-26 Flint automobiles and possibly others.
