Posts: 689 |
I am posting the following for a friend...what type of trans fluid is recommended for a '51 stock PG? Any additives? Thanks!
Posts: 3,008 Likes: 1
Posts: 3,008 Likes: 1 |
I am no xpert on this but my local Napa dealer recommended Valvoline MAX LIFE DEX/MERC for use in my 54 Power Glide. It is for Transmissions with over 75000 miles. Mine has 99900 miles and I am having no problems.
Joined VCCA June 1, 1961
The same Dexron fluid you would use in a 2000 model. Aditives are not necessary unless it leaks after being driven a distance. The Trans X works good if its a seal leaking but may take a year to swell the seal if the car sees only limited use.
Posts: 689 |
Thanks guys...I'll pass along the good info.
