Page 2 of 2 1 2
1931Sal #149459 08/11/09 01:51 PM
The smog pump will not affect the as milage. Here in Wisconsin they are supposed to be connected but the kids at the test stations don't know a smog pump from hole in the ground. I would bet that Ca. would be pretty fussy abvout it.
Chev Nut #149460 08/11/09 02:08 PM
1931Sal Offline OP
Maybe I will give a test by checking the mileage with and with- out it in use. Thanks for the comments. :vcca:
Sal Orlando
Chat Group Region Member
1931Sal #149850 08/16/09 01:20 PM
1931Sal Offline OP
One other thing, Do I need to use a lead addative in the fuel on this truck? Thanks.
Sal Orlando
1931Sal #149873 08/16/09 08:28 PM
Sal,
As I recall, the guys in the know say no need to use lead additive. Most call it a waste of money. Apparently no harm in using it; but not needed.
Bill.
1931Sal #149882 08/16/09 09:38 PM
The so called lead additives really do not contain lead or anything else that will give a benefit......no additives necessary.
Chev Nut #149888 08/16/09 10:01 PM
No lead additives in your 1931 and no lead additives in your 1967 El Camino either!
tonyw #149905 08/17/09 12:54 AM
Yes, and don't forget to replace the Themo activated fan clutch, if you have factory A/C. I had one go bad after servicing the factory A/C and using it on a 350 mile trip for no telling how long the A/C had been out of freon. The A/C worked fine, but....the fan clutch froze up and knocked the bearings out of it and also the waterpump bearing after using the A/C in 100 degree weather,
MrMack #149946 08/17/09 10:45 AM
1931Sal Offline OP
Thanks for all the replies. I didn't think I needed it but it never hurts to ask. As far a A/C this is a 250CI six cyl. Just bare bones with a heater and a radio. It did get hot on me when I drove it home from San Jose. A 200 mile trip. The temp light came on so I turned on the heater and it went out for a long time. I had the heater off for a while and when the light came on again so I just turned the heater on for the rest of the home. I did talk to a friend and he thought that there should be a fan shroud on this model. So that makes sense to me. I will look in the service book that I have and see if it is missing. Thanks again for all the help. :vcca:
Sal Orlando
1931Sal #149947 08/17/09 10:59 AM
I believe the 6 didn't have a shroud. If the fan is about an inch from the core it not have had a shroud.....and at 60 MPH it should not overheat with no fan or shroud. I would suspect the cooling system is dirty. These did not overheat when new but the had a real thin core.
1931Sal Offline OP
This does have a two row core. My cousin had some work done on it before he drove it to San Jose from north of the Golden Gate. One of things that is on the work order is flushing out the cooling system. The fan blade is more that one inch away from the radiator also. I could try flushing it out myself just to be sure. Thanks again for the input. :vcca:
Sal Orlando
1931Sal #150359 08/21/09 01:30 PM
I don't know if this helps but I have a 1966 el Camino base model CA car all it's life. It's a 230 six w/Powerglide and it has an AIR pump on it. Mine has a basic plastic radiator shroud on it. I assume it's original. I am the 3rd owner. And mine is very basic also. The only options: the bigger 230 six, Powerglide, AM PB radio, tinted windshield. No power steering no power brakes no A/C. Michael
Note my Aug 7th post said the models with air pumps had a shroud....so it sounds right.
Chev Nut #150405 08/21/09 11:30 PM
1931Sal Offline OP
Well now there is some thing else to check out. I will have to see if I can find one through some of the catalogs. Thanks for the input.
Sal Orlando
Page 2 of 2 1 2
