#149405 08/10/09 01:54 PM
123 Offline OP
Hi there,
This is the grease monkey again. First I want to thank all of you for the past information I received. It sure helped a lot. Now for the new problem.
I have a 51 chevy stile line coupe. When I put in reverse there is a clunk.
It has the power glide trans.TheMotor mounts and trans mounts are good and the u joint seems ok. It sounds like it is in the rear. It is only in reverse. I would not think this is normal
Any suggestions would be appreciated. Thanks
123 #149408 08/10/09 04:21 PM
This was normal under certain conditions. Mine will do it if the hand throttle or choke knob is out a little and it is idling faster. They did it when they were new.
If there is a problem it would probably be the ring gear and pinion have too much clearance. (the teeth don't fit close enough). But then the rear end could sing a little.
Chev Nut #149489 08/11/09 08:29 PM
123 Offline OP
Hi gene,
Thanks for the reply on the rear end clunk. I wasn't sure if they were made with that but what you said made sense. I will try what you said.
Thanks again Grease monkey 123
