#149169 08/07/09 05:11 PM
trooper Offline OP
Here's my quetion. bought the chassis GAGE, followed the procedure,brakes are improved. Q- the distance between the brake cross shaftis 4 1/2 instead of 3 5/8. Good or Bad?? trooper
trooper #149171 08/07/09 05:20 PM
The dimension between the clevis pin eyes on the front & rear brake cross shafts should be 3 5/8" as per both the repair manual and the service bulletins.Once this dimension is achieved,you will have the correct pedal travel and pedal reserve.
driving
CJP'S 29
CJP'S 29 #149206 08/08/09 07:46 AM
trooper Offline OP
Where do I make the adjustment? thanks trooper
trooper #149402 08/10/09 01:36 PM
trooper Offline OP
Installed the chassis gage, but the distance between the pins is 4 1/2 not 3 5/8. What do I do to adjust?? trooper
