#14912 10/03/05 09:01 PM
I have removed the mat from my running boards and find there are four depressions, one in each corner where the braces are attached. Are these supposed to be there?
#14913 10/03/05 11:45 PM
Yes they are made that way. The original mats were molded to the boards which filled the depressions. If a glue on mat is used these depressions must be filled with a body filler then the mat glued in place.
#14914 10/04/05 07:31 AM
Thanks Chipper
#14915 10/04/05 09:30 AM
filling station out of board mat for a 31. anybody got a source for the mat? thanks, mike
#14916 10/04/05 10:17 AM
You can try I&I Reproduction in California, but you will probably get the same response. :( :( :(
