Thanks Ollie
I corrected the ground at the body, sanded it real well, before I removed the tank, still no go. Thats why I took the tank out.
The other end to the ground that is soldered on the top of the sending unit was pretty solid. I took the sending unit out & hooked it up to a meter. I hooked up to 100 then 10 and as I raised the level, the needle went down & opposite when I made the float go down (needle went up). That sounds wrong doesnt it?
What am I doing wrong? I dont know much about these meters.
Thanks for your answer
Broo
