Whether to use DOT 5 Silicone based brake fluid and is non-hydgroscopis, or to use DOT 3 or DOT 4.
DOT 3 or DOT 4 and also DOT 5.1 which are polyethylene glycol based fluids. Fluids such as DOT 3 & 4 and 5.1 are hygroscopic and will absorb water from the atmosphere. This has positive characteristics and bad characteristics.
DOT 5 was designed to be used in military sealed systems that prevent water condensation in the system and water will not dissolve in DOT 5, but remains as water drops. The older Auto and truck brake systens are vented to the atmosphere and allow water to condense in the DOT 3 and DOT 5 brake fluid. This prevents the water being in drops and turning into steam in a very hot wheel cylinder, or from freezeing abd causeing a solid blockage in the brake lines.
However disolved water in a brake system that isn't used will cause corrosion in the wheel cylinders.
Boiling Point Ranges
Dry Boiling Point Wet Boiling Point
DOT 3 205°C (401°F) 140°C (284°F)
DOT 4 230°C (446°F) 155°C (311°F)
DOT 5 260°C (500°F) 180°C (356°F)
DOT 5.1 270°C (518°F) 191°C (375°F)
DOT 5.1 -- Long-Life Non-Silicone Synthetic brake fluid is a
EXTRA LONG LIFE 100% synthetic fluid for hydraulically actuated-brake and clutch systems. (Based on Polyglycol chemistry). DOT 5.1 has an expected operating life of up to 10 years
DOT 5.1 NON-SILICONE BASE suitable for up-grade from DOT 3 or DOT 4.
Fluidity specially designed for anti-locking brake systems (ABS).
Fully compatible and miscible with Conventional Brake Fluids.
This version has extra anti corrosion additives that protect ferrous, white and yellow metal brake system components.
This fluid is clear and golden yellow in color.
No special procedures are required when bleeding and replacing conventional system fluids with DOT 5.1
Does this help?
