valve adjustment for 206 1936 is inlet valve clearance .006" when is warm and exhaust is .013" when is warm. to set 1,3,5 exhaust, and 1,2,4 intake when rotor is pointing fire on #1 distributor cap and BB on fly wheel is on pointer. 6,4,2, exaust and 6,5,3 intake, fire on #6 distributor cap.... OR BB on flywheel is on pointer and fire on distributor cap is on #1 set #1 then rotate one turn on fly wheel to BB check should point be #6 of on cap. set one at a time. Additonal info....
Back of engin 6 5 4 3 2 1 front of vehicle
valve alignment EI IE EI IE EI IE
E=exhaust I=intake
