Posts: 597 |
Today I decided to clean up the hack job the previous owner did at the top of the vacuum tank. I noticed that the original tube that comes from the intake manifold and goes to the tank is made of a somewhat harder copper than what I can easily get at the local hardware store. Does anyone know what it is?
It's not how fast you can go, but how good you look at 20 MPH.
There is no specific reason for any material than what is available at your local parts house, or hardware store.
Posts: 2,418 |
May be you could ask Wallace F. Deck, proprietor of Teresa Crafts Restorations. He specializes in 27-29 stuff, but he can help with some other years too. 217-247-2162 or wdeck40000@juno.com
They are selling and repairing such stuff.
:vcca:
Solan G, # 32797
Posts: 3,192 Likes: 8
Posts: 3,192 Likes: 8 |
The copper tube you by from a hardware outlet is in the annealed condition, and is delibratley soft, to enable it to be bent to fit where ever it need to go.
When you bend it, it work hardens the copper, and becomes harder where it is bent, but remains annealed (soft) where it has not been bent. This is a natural characteristic of the copper.
JACK
Posts: 597 |
I know the hardware stuff is annealed and that is why it is soft, but the stuff on the car is exceptionally hard through the whole length. What I am seeing is not work hardening.
Actually due to vibration over and extended period any copper tubing used in an automotive application will "work harden".
Posts: 597 |
Ah, that would make more sense! I guess 81 years would definitely do a number on the copper.
Posts: 2,418 |
Hehehehehehe!  I also think we car dudes are turning more stiff after 81 years, stumbling around? Don't you agree????????
Solan G, # 32797
Posts: 597 |
Totally agree. Some days I too feel work hardened like the copper.
Posts: 173 |
Speaking of copper tubing, does anyone know where I could get 7/16" copper tubing and compression fittings? Every source I have checked goes from 3/8" to 1/2" tubing. I would appreciate any help.
Gary
Posts: 597 |
I have never seen that size, nor is it listed on any web site I can find. What is the application? perhaps that will help us help you.
Posts: 809 |
Be careful of old copper tube as a mate of mine who owns a 27 Chev and was 300 miles from home on tour broke the copper pipe that goes from the relief valve under the carby, through the block to the oil filter. As the break was where the pipe goes between no.2 and no.3 cylinder he still had oil pressure, however the oil was pumping through the broken copper pipe onto the road and he ran a bearing. The end of the break in the copper showed that it had crystallized. I've been told that you can re anneal the hard pipe with a gas torch or putting it in the oven for while. Best to replace with new pipe. Chris
Posts: 597 |
Back in my young and foolish days I used copper on a more modern car, before I knew better and it fatigued and cracked. I watch all the stuff on the 28 like a hawk. Call me paranoid. If my next door neighbour had his way, he would change it all to stainless.
