#145912 06/19/09 03:27 PM
in2deep Offline OP
I am restoring the door handles on my Master and have no key to the door. I think the blank is a B&S #11 and I have the code from the shank but the locksmith does not have the "key bitting" or the "specifications" to cut it.
How do you get the lock cylinder out of the handle?
Can anyone assist?
Thank you, Jerry
there is a pin that you have to punch out look real close on the shaft and you will find it it is about the size of a small nail some times they are piened over and it is hard to find hope this helps
in2deep Offline OP
Searching for the pin in the corrosion today.
Thank you, Jerry
