Hi Shock's,
The TILLOTSON "JR" series of carby's were a good source for a carb that would run better than a worn out original one.
There are a few differences,the main one's being the venturi size,which is either cast on the outside of the carb,or is cast on the underside of the top half of the carb,which will be visible after you remove the float.
Most "JR" 1,1A,3,5A carbs had either a 7/8" or 15/16" venturi.The "JR" 2A which had the cast iron top body,and diecast lower body,has a venturi size of between 15/16" to 1".If the venturi size is too large for the engine,it will run fine at high speeds,but run rough at idle,as the larger venturi admits too much air.
Other factors that affect the idle of these carbs are,float height set incorrectly,float travel set incorrectly,the idle feed tube could possibly be swapped from another "JR" carb(all use the same threaded tube,different jet hole at top end)and possibly the main jet has been swapped from another "JR" carb.Another factor which will affect the performance of these carbs is that where the main jet seats in the lower half of the carb,there is a fibre gasket which fits over the end of the main jet.(Worn throttle shaft bushes will also affect idle as well.The original ones are steel(removable),and I replaced mine with hard nylon ones,which saves wear on the shaft).
If this gasket does not seal properly,the engine will draw excessive fuel past this seat,and give a rough idle due to over richness.I've found that by replacing the red fibre gasket with an "O" ring,the seal is as perfect as it can be made,and this solves any more trouble,as the diecast can distort over the years,and the soft "O" ring makes up for any deformities in the diecast.
A real good source of informatin would be the carburettor book put out by "A.L.DYKE".It's full of information on various carbs,and has a section the "JR" series carbs.I also have some other book's with information on these carbs.If you're interested,I could possibly photocopy the info for you,and send it to you.
I,myself,wouldn't put my original CARTER carb back on my '28 truck,as it goes so much better,and I get really good fuel economy.
Hope this helps you out in some way.If you'd like to contact me directly,my email address is:
wizardsmith278@optusnet.com.au
