#145264 06/09/09 08:56 PM
DavidR Offline OP
Can anyone tell me if the 33 chevy-cowl lights are the same as used on the other model vehicle; such as the 33-Fords????Where can they be found??? Thanks Dave
Become a Member!
David-We don`t use those four letter words here, it`s "F@#Ds".
Sorry, I just had to do that. The 33 Cowl lights are one of a kind, although the bucket is the same as the 32,the rims have the widows peak as do the tail and headlight rims. "F@#ds" are alot different. It`s not easy, but they can be found. The rims I believe can be purchased from I & I Reproductions and if you can find some 32 buckets, then your in business.
hoppy
"Four-Doors-Forever"
DavidR Offline OP
OK- Hoppy------thanks for the info. DavidR
